- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Report Inappropriate Content
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
2023 @ BODAS Connect A short reflection |
As the year 2023 comes to a close, it's time for BODAS Connect to reflect on what has been achieved and what the future holds. The past year has been transformative, marked by growth and innovation. BODAS Connect continued to push forward and achieve significant milestones. In this year-end review, we take a closer look at those achievements and milestones, and share what’s ahead in early 2024.
Product News |
- Universal Flasher: to flash any ECU* over the air
- FOTA any UDS-based ECU in a machine via BODAS Connect.
- OEMs & partners can bring proprietary flash algorithm for any ECU and integrate it into the RCU, while protecting their IP.
- *ECU pre-requisites: UDS-conform & known flash algorithm
- Parametrization over the Air for RC40
- Calibrate machines with RC40 over the Air
- Just upload complete BXML file via the Device Portal
- Further improvements and additional functionalities planned 2024
- Simplified Onboarding for setting up new RCUs: say goodbye to USB Sticks and Email ping pong.
- All new RCUs now come with centrally handled certificates, which are updated over the air upon connection. So no more Emails to Support Team asking for certificate files.
- All new RCUs can update their configuration online via the Device Portal. So no more USB sticks (except in some special cases)
- Data Portal has simplified setting up & customization dashboards & includes an instruction manual under "User Documentation" within each project/cloud instance
- myBODAS as the new central platform for all things BODAS: get all your information anytime online
- Uses same login as other BODAS Connect portal, i.e. the SingleKeyID.
- All new updates and release notes shall now be centrally published under Release Notes.
- Get all updates directly into your inbox by subscribing to the "BODAS Connect" label.
And many more like:
- Campaign Management for updates to RCUs in multiple machines simultaneously,
- revamped Fleet Overview in Data Portal,
- configurable polling intervals to optimize cellular data usage
How BODAS Connect helps in real life |
BODAS Connect saved our customers innumerable hours & euros of travel:
- Downtime
- Challenge: A vehicle subsystem fails while in operation.
- Solution: Diagnose active errors via Diagnosis RC30 feature & fine tune corresponding domain controller parameters via POTA
- Legal Liability
- Challenge: End customer not happy with the performance of the machine
- Solution: Using Data Management, analyze machine data for observing performance remotely and then once root cause is identified, an adapted software and calibration can be rolled out via Device Portal.
For 2024, you can look forward to… |
- The all new RCU Lite: a lighter RCU for all basic telematic functions. Shipping from Feb. 2024
- Bluetooth beacon support
- Revamped UI: Machine Details, Fleet Overview and Easy Customization
- Improved event monitoring to configure alarms in Data Portal
- Valuable new use cases with our partners, for e.g.
- Talpa Solutions, for machine usage analysis, over-the-air services for engine ECUs, and tire pressure monitoring
- irdeto for contactless machine access, especially in construction rental industries.
Let's Go! 🚀 |
With all hands on deck and a clear vision in mind, the BODAS Connect team is ready to soar to new heights in the year to come. 2024, here we come!
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
