To access the Adaptive Ground Drive group in myBODAS (including the download area), please follow the steps below:
You will first need a SingleKey ID to access myBODAS. Please refer the following link to create your SingleKey ID.
Once your SingleKey ID is created, you can login to myBODAS using it.
Note: We recommend using a clear name as your nickname (no pseudonymns), so that members can be easily identified within the group.
To access the Adaptive Ground Drive group, request the Adaptive Ground Drive access role, 'mbc_agdrive' by sending a short email to [email protected].
Once onboarding confirms and your access role is assigned, you will be able to access the Adaptive Ground Drive group and the download area in myBODAS.
Hint: If you were already logged into myBODAS (after receiving confirmation from onboarding) please log out and log in again to ensure the changes take effect.
